Page 1 of 2
PX200 wont start when warm
Posted: Thu Jul 10, 2014 9:51 pm
by davepeters
Hi all
My standard PX200 has problems firing up afther being stoped for a short time. This is resolved by taking off the carb cover, then it kicks up straight away. Bike kicks over fine when cold. Has anybody any ideas how to solve this? Cheers Dave.
Re: PX200 wont start when warm
Posted: Thu Jul 10, 2014 10:19 pm
by mick1
strip and clean carb' and filter.
Posted: Thu Jul 10, 2014 10:33 pm
by GLscoot
Have you checked your plug.
gary
Posted: Thu Jul 10, 2014 10:46 pm
by lambro
Take he waterproofs out from under the seat/rag out that you store in the vent hole under the seat.
Just a thought
Posted: Fri Jul 11, 2014 12:46 pm
by Jack221
If everything else is ok then the pilot circuit is too rich. Check the air screw on the back of the carb is no more than about 1.5 turns out.
Posted: Fri Jul 11, 2014 3:44 pm
by mick1
could be choke sticking on or not returning fully....
Posted: Fri Jul 11, 2014 4:41 pm
by santacama
Jack221 wrote:If everything else is ok then the pilot circuit is too rich. Check the air screw on the back of the carb is no more than about 1.5 turns out.
Shouldn't it be 2 to 2 and 1/4 turns out.
Posted: Fri Jul 11, 2014 4:44 pm
by santacama
davepeters wrote:Hi all
Reason is been to reach..... probably.
Posted: Fri Jul 11, 2014 8:20 pm
by santacama
santacama wrote:davepeters wrote:Hi all
Reason is because it is too rich..... probably.
Posted: Fri Jul 11, 2014 8:51 pm
by davepeters
I thought it might be the air mixture screw as well but thats at the default setting of one and a half turns out. Maybe I should lean it out a bit?
