PX200 wont start when warm
davepeters
Main scooter: px200efl
Hi all
My standard PX200 has problems firing up afther being stoped for a short time. This is resolved by taking off the carb cover, then it kicks up straight away. Bike kicks over fine when cold. Has anybody any ideas how to solve this? Cheers Dave.
mick1
Main scooter: Li Avanti 225
strip and clean carb' and filter.
GLscoot
Main scooter: Vespa GS150
Have you checked your plug.
gary
lambro
Take he waterproofs out from under the seat/rag out that you store in the vent hole under the seat.
Just a thought :D
Jack221
Main scooter: PX221
If everything else is ok then the pilot circuit is too rich. Check the air screw on the back of the carb is no more than about 1.5 turns out.
mick1
could be choke sticking on or not returning fully....
santacama
Jack221 wrote:If everything else is ok then the pilot circuit is too rich. Check the air screw on the back of the carb is no more than about 1.5 turns out.
Shouldn't it be 2 to 2 and 1/4 turns out.
santacama
davepeters wrote:Hi all
Reason is been to reach..... probably.
santacama
Reason is because it is too rich..... probably.
davepeters
I thought it might be the air mixture screw as well but thats at the default setting of one and a half turns out. Maybe I should lean it out a bit?
