Mikuni TMX30
Fruitjuice
Yesterday I started up my Monza 225 with TMX30, 58mm crank and Kegra racing exhaust. Timing was set at 17°
Jetting for now is:
Main: 250
Idle: 40 (friend advised 35 but don't have one at the moment)
Needle is what came with the carb and the clip is in the middle position
A friend of mine that runs a TS1 225 with a TMX30 and PM pipe gave me his jetting, and I expected this to be close, but my jetting seems very rich...
I'm thinking he has the TMX30 without the powerjet since he didn't give me a jetsize for one.
Exactly how much difference would a powerjet make across the range, or is this purely the top of the range that's affacted?
And if so... will my mid range be weak if I put in a smaller main jet to compensate for the powerjet, or is his midrange maybe too rich, so his top end can be spot on?
Bufficus
Your pilot jet is way too big.
I used to run a TMX30 on a TS1 with a 25-27.5 pilot, standard needle on the second clip and a 280 main jet. Power jet blanked off. They don't seem to work on these carbs on Lambrettas.
Fruitjuice
Will try a 25 idle tonight then...!
