Mmw/lth hydraulic front brake anti dive washers.
Posted: Thu Jun 26, 2014 7:24 pm
by Ihateyoubutler
Anyone know what these type of washers are called and where I can find some in the uk? They're the 8mm ones either side of the rose joints on the anti dive bar, with a rubber seal fixed to them.
Thanks.
Re: Mmw/lth hydraulic front brake anti dive washers.
Posted: Thu Jun 26, 2014 8:58 pm
by rosscla
Believe they're called dowty washers or something similar
Posted: Thu Jun 26, 2014 10:40 pm
by warts
Sounds like a Dowty washer.
https://www.google.co.uk/search?q=Dowty ... B800%3B600
Try a bearing/seal place if you can't find a specialist hydraulic shop.
Posted: Fri Jun 27, 2014 4:59 am
by Ihateyoubutler
The're not dowty seals ( for banjo bolt unions etc), they are a flat washer with a cup shaped washer stuck to one side that protects the rose joint. Don't know what the're called, so having difficulty searching for them.
Thanks.
Posted: Fri Jun 27, 2014 8:12 am
by jason frost
Posted: Fri Jun 27, 2014 8:13 am
by jason frost
Posted: Fri Jun 27, 2014 12:49 pm
by Ihateyoubutler
Thanks for your help.
