Mmw/lth hydraulic front brake anti dive washers.
Ihateyoubutler
Anyone know what these type of washers are called and where I can find some in the uk? They're the 8mm ones either side of the rose joints on the anti dive bar, with a rubber seal fixed to them.
Thanks.
Believe they're called dowty washers or something similar
warts
Main scooter: honda
Sounds like a Dowty washer.
https://www.google.co.uk/search?q=Dowty ... B800%3B600
Try a bearing/seal place if you can't find a specialist hydraulic shop.
Ihateyoubutler
The're not dowty seals ( for banjo bolt unions etc), they are a flat washer with a cup shaped washer stuck to one side that protects the rose joint. Don't know what the're called, so having difficulty searching for them.
Thanks.
Ihateyoubutler
Thanks for your help.
