clutch
jonboy
Main scooter: Vespa T 5 Classic
help please
Out on the lambretta yesterday everything was fine.
got into traffic and was lot of stop start, i then pull in clutch and engine stalls got it into neutral started it up again put it into first and same thing happened. it then started to function properly again but when i accelerated felt as though speed did not correspond with revs. it was working fine for first 15 20 minutes
bristolmod
if you are lucky its just adjustment- you need some free movement at the handlebar lever (the old WSM says 1/16th inch)
However, if its been wrongly adjusted for a while, its likely the plates have worn which could be the reason for your clutch slip ("speed did not correspond with revs"). In that case new clutch plates (corks steels and springs if you are dismantling anyway)
Gear box oil level? checked?
Gear cable routing?
Chris
Scootering since 1968.
jonboy
have not used scooter for 7 months could this have any input
speedy
Had you disconnected the clutch arm whilst the scooter was standing?
jonboy
no
mick1
Main scooter: Li Avanti 225
It sounds like you have 2 problems: the clutch is not disengaging when pulled in (hence the stalling when selecting 1st) and a slipping clutch...Further adjusting the clutch to solve the first problem would probably compound the problem of the second ?
I would first try a new outer and inner cable, if that fails it's the clutch out...
jonboy
would not using for 7 months have any influence
mick1
I doubt it. There's loads of lads who only use their scooters between May and August :? and they're stood for the rest of the time. If you had oil in the engine i wouldn't have thought it would cause a problem.......if it did it would be the stalling when engaging gear....
jonboy
That means for me that i got 20 miles out of the lambretta before it developed a problem.
joespeed
why not dive in and have a look its a fooking lambretta not a nasa space rocket!
