Warm starting not
Posted: Fri Jun 20, 2014 9:12 pm
by jazzyb
Hi peeps before I go and pester waddo my mates 150 special starts first kick runs a dream but when warm a b••stard to start not great we engines so be kind Bog standard with 175 kit fitted years ago no other probs at all thanx jazzy 8-)
Re: Warm starting not
Posted: Fri Jun 20, 2014 9:27 pm
by mick1
Restricted air flow or to much fuel. Choke sticking might be an option ?
Posted: Fri Jun 20, 2014 9:41 pm
by Bilko
Worn rings?
Posted: Fri Jun 20, 2014 9:42 pm
by nuttyboy
Had same problem was air leak in split carb rubber.
Sent from my KFTT using Tapatalk 2
Posted: Fri Jun 20, 2014 10:44 pm
by Mr G in NYC
not in any order but have a look at......
Spark plug gap/ correct plug ?
Float needle worn ?
Blocked or worn pilot jet ?
Blocked air filter
choke cable seated correct ?
I have a stock DL 200 thats a bitch to start after a run .
So now I switch off the fuel just before I stop and run
the carb bowl half empty ........Then when I restart it
I leave the fuel tap and choke off and it starts first kick.
Stock old SH/22 dellorto that one of these days I'm gonna
swap out for a NOS one I have sitting in the garage...
Good luck bud 8-) G 8-) .
Posted: Sat Jun 21, 2014 4:32 am
by jazzyb
Cheers all thanx g it's Steves golden special who popped in to c u with me last year 8-)
Posted: Sun Jun 22, 2014 10:42 pm
by rainbowrunner
I,m having the same problem (only now and again tho) 175 top end, new everything, all run in etc from cold starts first kick with choke, switch off at garage for fuel starts again first kick, problem is if i leave it 10 or 15 mins it can be a bitch, been told it could be my pilot jet, got in a 50 ! would a 45 or 48 be better.
plugs a nice colour and no air leaks
