Spanish LI Rebuild
sp1v
Appreciate some input here - Got a Spanish LI150 frame with steering stop on back of fork tube which I believe makes it a non chrome ring frame (but could be wrong just making assumptions after research), legshields which have been trimmed at the top between horncast mounts for some reason and forks which are 467mm from bearing track seat to top of stem which I believe makes them chrome ring type forks. Bought bike which was running fine with standard SX type headset and no chrome ring. Bought some drops (from Scooterotica) which are non chrome ring type. If I want to replace the forks with some Scomadi's which length/type should I be buying considering drops are non chrome ring, same as I have 467mm or different? Cheers
