flywheel tightening without a holding tool
- registered user
- Main scooter: lambretta 125 series 2 TS1
- Contact:
T5 flywheel. Is there a good way to tighten one without a holder without breaking the fins?
In an Emergency only:
1) Ratchet strap round the flywheel secured on the kickstart boss.
2) Clothesline rope down the spark plug hole to block the piston travel
3) stick it in gear and put the front wheel against the wall, get your fattest friend/girlfriend to sit on the scooter and apply both brakes then go for it
WTF
WTF
plastic handled screwdriver between the selector box and flywheel, the handle chews up before the fins snap.
- registered user
- Main scooter: Lambretta
- Contact:
Better still, two plastic handled screwdrivers - one against the selector and one against the kickstart, spread the
load
load
- registered user
- Contact:
Thanks for the replies.
The screwdriver trick did the business, no broken fins!!
