Its air filter time!!
kevspeed
Hi all,ive always run open carbs on anything tuned,have done since the eighties,never had a problem,except for 5 miles out of Tenby in 2005,when one of the sidepanel grill fixing plates got swallowed by my 30 Dellorto,resulting in one fu**ed TS1!!
Anyway,im just re-vamping my TV200,you know the thing,good clean up/service/tyre pressures/adjustment here and there!,anyway,its been run with an open 30 Dellorto behind a panel with no hole cut in it,so you can imagine the mess,what with the spitback etc.....
Its always run fine,and the mess never really bothered me............until now!
I have aquired a 'Ramair' filter,fitted to a fairly stiff airhose,and would like to use it,if only to keep the frame internals a bit cleaner!
Obviously its going to affect the jetting somewhat!,so what im asking is this.
Roughly how much have you filter users had to reduce your jets by when fitting a 'Ramair' set up?
I understand that all engines are different,and trial and error is the way to go,but i would like to speed up the process a bit.
My jetting was......Main 125,atomizer AV266,Needle X7,Pilot 55,Slide 40.,thanks in advance...........Kev
SpanishSX200
Kev,
I'd be looking at between 10-15% smaller on the main and pilot. You should be ok with the choke jet, atomiser, and slide. You can use the clip on the needle if you need to.
Simon
