Rear Footboard Dzus Clips
Posted: Thu Apr 24, 2014 10:19 am
by Bilko
Is anyone using these for their rear footboards?
I'm unsure which ones to get and need pointing in the right direction
Re: Rear Footboard Dzus Clips
Posted: Thu Apr 24, 2014 7:43 pm
by TED CRUD
Posted: Fri Apr 25, 2014 9:50 am
by Bilko
Thanks Ted.
Are you using those?
Posted: Fri Apr 25, 2014 10:21 am
by corrado
I think we used something like these on the racer, Jason would know.
http://www.ebay.co.uk/itm/2x-Dzus-Faste ... 27df976700
These are a cheaper version on the Demon Tweeks one.
http://www.ebay.co.uk/itm/Slide-Latch-B ... 4d1bb56fe3
Posted: Fri Apr 25, 2014 6:53 pm
by TED CRUD
https://www.google.co.uk/url?sa=i&rct=j ... 4656999163
I will be doing the same as the pic on my GP
Posted: Fri Apr 25, 2014 7:08 pm
by Bilko
Thanks Martin, thanks Ted. Appreciate the links.
Posted: Fri Apr 25, 2014 7:37 pm
by TED CRUD
I will be using the Dzus clips with a Lambretta Bridge fitting Kit .Racers use two clips on the outside of the runners and fix the bridge piece in place with bolts using a spacer .The floorboards need to be notched around bridge piece bolt/spacer
Resulting in very fast removal of the rear boards
