Rear Footboard Dzus Clips
Bilko
Main scooter: LI150
Is anyone using these for their rear footboards?
I'm unsure which ones to get and need pointing in the right direction
Bilko's Oily Blog
Bilko
Main scooter: LI150
Thanks Ted.
Are you using those?
Bilko's Oily Blog
I think we used something like these on the racer, Jason would know.
http://www.ebay.co.uk/itm/2x-Dzus-Faste ... 27df976700
These are a cheaper version on the Demon Tweeks one.
http://www.ebay.co.uk/itm/Slide-Latch-B ... 4d1bb56fe3
TED CRUD
https://www.google.co.uk/url?sa=i&rct=j ... 4656999163
I will be doing the same as the pic on my GP
Smash Ya Pastie
Washington Posse s.c
Bilko
Main scooter: LI150
Thanks Martin, thanks Ted. Appreciate the links.
Bilko's Oily Blog
TED CRUD
I will be using the Dzus clips with a Lambretta Bridge fitting Kit .Racers use two clips on the outside of the runners and fix the bridge piece in place with bolts using a spacer .The floorboards need to be notched around bridge piece bolt/spacer
Resulting in very fast removal of the rear boards
Smash Ya Pastie
