t5 mk1 forks
blast
Main scooter: li150 special
are these the same as px forks,as im selling my mk1 frame and headset for a px
Juan
No, the bottom 7/8's or so are much the same but the top part of the stem is threaded for ring fixing as opposed to a pinchbolt arrangement for PX's etc. The mudguard side fixing lug is also in a different position, can't remember if there's anything else as not looked at a set in over 15 years.
blast
thanks,looks like ill have to sell these as well
goldeneye
you can put T5 mk 1 forks headset etc in a PX frame and viceversa, but the bits arnt interchangeable, the top bit is threaded instead of a pinch bolt. BUT, some late LML square headlamp models had the pinch bolt like a PX, and some had a disc brake master cylinder mounting! TX 200 Spanish models use the threaded forks also.....as do COSA"s....
soulboy
as above put I cant understand why u wanna swap for a px frame
blast
i dont like the shape of the rear on the mk1 frame and much prefer the curve
of the p/px
lambro
blast wrote:i dont like the shape of the rear on the mk1 frame and much prefer the curve
of the p/px
Buy a spot weld drill and remove the square tail then,
'tis but a standard (ish) PX underneath.
jackson85
Main scooter: T5mk1
Remove our carefully and you can sell it to someone with a square tail with a rotten arse
soulboy
are you selling it
