it normally runs with an airbox in the original bike, but Im running a ramair filter, just to be awkward and because an airbox wouldnt fit
I can get a lovely smooth idle, BUT only if the adjuster is fully wound in, and I adjust the cable to take it up a bit, it should be possible to get it idling with no cable.
I think??? that I need to adjust the pilot jet, but what way to go with it, I assume smaller, as Im having to open the slide to let more air in to counteract a rich pilot?
would this over rich pilot also cause revs to hang a bit and be slow to settle down
thanks in advance, the bike forums want to know what model you have, and as I havent a clue what it is, they are a bit funny, usually just saying, put the airbox back on, you lot are far more learned and open minded in my experience
