Spit back on amal carb
Posted: Wed Apr 02, 2014 2:30 pm
by roadrunnerian
hi my mate has a rapido 225 with an amal 34mm carb 320mj needle jet 207 needle2D1 pilot 35 choke50, the problem is he has a lot of spit back and is very boggy and running rich any ideas thanks
Re: Spit back on amal carb
Posted: Wed Apr 02, 2014 5:45 pm
by fairspares
There is only one answer to your question, you need to get the carb set up by someone who knows what they are doing and or on a dyno.
Posted: Wed Apr 02, 2014 5:54 pm
by sean brady scooters
a dyno session is deffo in order here to check things out ,as fairspares recomends .
but its quite normal for a certain amount of spit back to occur at low revs on a tuned (piston ported )motor...has the inlet timing been extended /piston skirt cut ?
how does it perform and run generally ?
Posted: Wed Apr 02, 2014 7:10 pm
by roadrunnerian
thanks for the replies i did tell him to get it set up on a dyno but i'm afraid he is running a very tight budget,its very boggy when setting off only clears when the main jet kicks in.
Posted: Wed Apr 02, 2014 7:20 pm
by Timbo
Fit a remote...
Posted: Wed Apr 02, 2014 7:29 pm
by fairspares
can you give us a bit more info , if its not had any tuning work and is a rapido classic it could be a case that the 34mm carb is to big.
Posted: Thu Apr 03, 2014 1:43 am
by modpopcomedy
Id go along with the above ian. Aint no need for a 34 carb on even a half decent tuned rapido bud. No wonder the guys skint ...lol. get him over to petes mate. .wat size do u av on ur hb ts1? Itt smaller than that isn't it? An id guess urs higher state ov tune. Psl visit for him.:) steve.
Posted: Thu Apr 03, 2014 9:49 am
by soosh
What no.slide being used,i found 4 works best. Also is the needle new or an old one? New needle will make a difference. These carbs should be easy to setup and you only have one size needle to play with.
