I am at thee dreaded wiring point in the build and have managed to get the SIP speedo wiring through the frame, little easier than I thought, have not looked at connected it yet, are there any things I should be wary off. Do I have to use relays or inline fuses before connecting to the battery, these questions might be a bit anal, but Im really not that confident or any good with electrics and don't want to fucck up the speedo. Any basic help will be appreciated.
Gary
Vespa SIP Digital Speedometer GS VBB
- hobospeed
- registered user
- Contact:
I found it pretty straight forward when I did mine. I run an all AC (non battery) set up so it's not exactly the same as yours. I just tapped the tach/rpm wire and power wire to a hot wire in the headset (I used the running light) and hooked the seedo's ground to negative wire at the head light junction/bulb holder. If you plan to run your speed off of DC (battery) then you want to make the sure power feed is fused. I don't see why you would need a relay. Where are you putting the black box for the speedo? I have mine in the headset and found that self adhesive velcro worked nicely to keep it in place yet still be removable if I need to do work on cables and pulleys.
Good luck,
Tim
Good luck,
Tim
