R1 spring change
Boreham
Main scooter: GP225
Does this require any special tools, can it be completed DIY? Just need to fit my nice new spring from Chiggy Chambers
Eibar
Main scooter: Eibar TS1 1966
spring needs compressing to go on damper body. You may getaway with ratchet straps if you aint got soring compressors
potato
Angle grinder to get the old one off. Put kettle on.
Compress new one in a vice. Put a few zip ties round it. Pop it on. Snip zip ties. Make cup of tea.
Boreham
Main scooter: GP225
Muttley McLadd wrote:Angle grinder to get the old one off. Put kettle on.
Excellent and simple explanation.......... twitchy bum time when you cut the ties.... but standing back proudly with the cuppa and smug grin work wonders!
immylam
Where sells the new springs? I have a 180 spring - what exactly does this mean, rider weight?
DaveTomo
Main scooter: SX 200
immylam wrote:Where sells the new springs? I have a 180 spring - what exactly does this mean, rider weight?
Chiggy Chambers http://www.lambrettaupgrades.co.uk/r1-springs-bushes 180lb spring solo riding - 220lb two up or for the fuller figure
immylam
I weigh 205lbs but always solo ride , is my 180 ok or should I be upgrading? Only ever rode with standard springs before.
wack 63
Main scooter: '71 GP TS1
Stick with the 180 and use the compression damping and pre-load adjuster to suit the load
    Users browsing this forum: Amazon [Bot] and 8 guests
