Jet into SX
lammydave
no... not me trying to make my Jet look like an SX...but....
My Jet performer is stripped waiting for a resto job...
My Italian SX with electronic ignition has engine issues... don't ask.... grrr...
anyways, the Jet engine is obviously lounging around doing not a lot... and with only 1400 miles from new on it, I'm tempted to slot it into the sx frame...BUT.....
The stator wiring is as stickys book on page 271...
so, it has 6v points ignition, but does run a motoplat rectifier....
there are 2 yellows, 1 red and a green from the stator...
is there an easy way to use this in the sx??
camel
Yes...use the sx stator and flywheel.
lammydave
camel wrote:Yes...use the sx stator and flywheel.
not sure, but I think the crank on the Jet is LI type, so the taper will be smaller... or is it??
CPH Lambretta
Main scooter: DL 150 1970
LI-SX same same :)
Slow is the new fast!
