crank for DR 130
90 with DR 130 fitted
new crank needed.
has electronic ignition
currently using oe crank
so thinking need 19/20 M10 on flywheel side, 51 stroke
without spending huge amounts, the Mazzuchelli cranks seem to fit the spec, but these would not be my preferred crank to fit to a Lambretta, are they ok for smallframes ?
engine has primmy 4 speed, 19/19 carb [but may upgrade that later...]
so are the Mazzuchellis fit for use, or other recommendations...?
thanks
jonny snatchsniffer
have a look at the bgm cranks at scooter centre koln
a small taper crank wouldnt be my first chioce as the tend to snap no matter the make, maybe safer with a 1kg flywheel
