Mikuni 35mm TMX - Exploded View
FREE tuning and maintenance info, plus links to our original tuning pages that started it all off.
carlos fandango
Mikuni TMX35mm
o. Description Part No.
1 Mixing Body Carb TM38SS11
2 Jet Needle J8-SEE TUNING
3 Cover, Carb Top 776-19014
4 Lock Nut, Adjuster B30/247
5 Cap, Rubber VM34/282
6 Adjuster, Cable VM30/77
7 O-ring, Top Cover 616-93009
8 E-ring, Needle Clip BS32/126
9 Ring, Retaining TM38/54
10 Adjuster, Idle Stop 603-25008
11 Spring, Idle Adjust N110209
12 Plunger, Starter Assy TM38/57
13 Screw, Air Adjuster 603-36002
14 Spring, Air Screw VM15/112
15 Chamber, Float Bowl TM38/48
16A Valve Seat, NDLE Assy 786-36004-(2.5)
16B Valve Seat, NDLE Assy 786-36004-A-(1.8)
17 Pilot Jet VM22/210-SEE TUNING
18 Main Jet 4/042-SEE TUNING
23 Cap, Float Retainer VM26/42
24 Screw, Top Cover CW2=0412
25A Throttle Valve 999-832-014
25B Throttle Valve 999-832-017
26 Spring T.V. 730-13019
27 Hose, Vent 888-24011
28 Screw, Float Bowl CW2-0308
29 Hose, Overflow 888-23022
30 Float, Left Side 859-52021
31 O-ring, Drain Plug BN042/64
32 Drain Plug TM38/44
33 Float, Right Side 859-52020
34 Gasket, Float Bowl TM38/52
    Users browsing this forum: No registered users and 25 guests
