Tuning definitions please if you'd be so kind
speedy
Just out of interest,as I have no knowledge whatsoever regards a couple of terminologies that you hear quite often. Firstly,regards the Avanti tt3...What does MWO port layout/design mean? Secondly the one I hear a lot now and through the years is Boyessen ports,layout and reeds. Sorry if I sound a bit naieve,but I genuinely have never known what they mean :oops: cheers,Speedy.
speedy
Anyone?.....Please!
I forget exactly, but the MWO is something like Moss Wrap Over port, it refers to a type of feeder port on the piston port TT3 kit which feeds from the main transfers to a port on the back wall of the cylinder.
Boyessen was the surname i believe of the chap who pioneered the research of feeder ports which directly connected the inlet area of a reed valve engine and the main transfers. He also developed other items like dual stage reeds (standard reeds were a single layer, his were a dual layer).
DigDug
There is some blurb on the Supertune websight.
Did you have to do that?
speedy
Aha thank you both,that's much appreciated. It was just one 'or two as it goes,terms that I just didn't understand. I know know what it means when I next see either in print,cheers,Speedy.
