Ahh, those wires.... Help please
Fux
Main scooter: li150 S2
Iv`e been messing about with my series 2 (li150) for over a year now and tonight I finally got it running. 8-)
I have, however no lights and on a loom that worked fine before the re-build.
I have fit a Jockey`s headlight conversion, so I had to take out the headset wire junction thingy.
Up front I have a casa li s.2 switch and the original kill switch (no ignition key)
Which wires should be connected to what?
is this on the loom I built for you ?
if so, I'll have a diagram somewhere
Fux
Hi buddy, The TV worked a treat and I still have the diagram you made for me and it still works, just under a different rider ( ie. sold the bugger)
The one I have now is simplified loom, 12v. Just not simple enough for me how to figure out how to wire up the li switch... :oops: :?
good to hear the TV is still running well
I'm not familiar with the jockey headlamp conversion, got a diagram ?
Fux
Its just a Halogen headlight, it sits a little to deep in the headset to be able to use the original conector thingy. Three wires.
http://www.jockeys-boxenstop.de/shop/en ... ?q=halogen
I wont use the pilot light because daytime headlight is compulsery in scandie.
can't tell much from those pictures
you need to get the rubber cover off, and see where the wires go...
is it bayonet bulb, or H4 type ?
Fux
Its a H4.
