RT195 26mm Delly + Clubman jetting
Posted: Wed Feb 26, 2014 10:57 pm
by Mike - - Bristol
Any one give me a head start with jetting , just getting everything back together and could do with a guide.
Cheers guys.
Re: RT195 26mm Delly + Clubman jetting
Posted: Sat Mar 01, 2014 3:10 am
by corrado
My muggy 225 with 26mm PHBH and ADS3 exhaust seems OK, tad rich throughout, with X13, AV266, 125 main, 52 pilot, breath sweet filter.
Posted: Sun Mar 16, 2014 1:49 pm
by Special X
52 pilot X13 2nd clip (may need 1st clip if over rich AV266 110 main Will be a little rich all the way. After a few plug chops you might need to go to AV264 with the needle on 2nd/3rd clip. You'll need a bigger main if you put an expansion on it.
Posted: Sun Mar 16, 2014 9:01 pm
by jason frost
Which clubman? inlet manifold ? and have you changed the needle valve ?
Posted: Sun Mar 16, 2014 10:11 pm
by Mike - - Bristol
Thanks guys.
Jason it's a 42mm Clubman , matched 200 inlet. Not changed anything just gathering info at the moment.
My plan is to get it close until it's run in and then maybe go 30mm and I have a PM expansion pipe.
