RT195 26mm Delly + Clubman jetting
Mike - - Bristol
Main scooter: Silver Special 195
Any one give me a head start with jetting , just getting everything back together and could do with a guide.
Cheers guys.
My muggy 225 with 26mm PHBH and ADS3 exhaust seems OK, tad rich throughout, with X13, AV266, 125 main, 52 pilot, breath sweet filter.
Special X
52 pilot X13 2nd clip (may need 1st clip if over rich AV266 110 main Will be a little rich all the way. After a few plug chops you might need to go to AV264 with the needle on 2nd/3rd clip. You'll need a bigger main if you put an expansion on it.
jason frost
Which clubman? inlet manifold ? and have you changed the needle valve ?
Mike - - Bristol
Thanks guys.
Jason it's a 42mm Clubman , matched 200 inlet. Not changed anything just gathering info at the moment.
My plan is to get it close until it's run in and then maybe go 30mm and I have a PM expansion pipe.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
