What's your favourite 210 malossi exhaust
Posted: Sat Feb 22, 2014 10:40 pm
by ricalnic
Ok, currently I run a Taffspeed RHS exhaust on my Malossi 210. Running T5 4th, ported cases, cut crank, and high flow std si24 carb. It's a great exhaust and comes on pipe at the higher revs. Better than the Revolver that I had on it before.
I'd like to try something else this year, so what do other Malossi 210 riders use and rate ?
I'm not after a torque tour monster, I want revs, speed, power......more...
What have you got ?
Re: What's your favourite 210 malossi exhaust
Posted: Sat Feb 22, 2014 11:52 pm
by bazman
Holed piston..
JL Right Hander
Posted: Sun Feb 23, 2014 7:34 am
by LI150
I use a JL right hand.
Have you looked at the bullet pipes I fancy one of these next.
http://www.pipedesign.de/engine/index.php
Posted: Sat Apr 12, 2014 10:16 pm
by Norrie Bodge
PM-Evo with similar setup to yours but using a T5 24/24g carb...
Vroooooomm
Posted: Sat Apr 12, 2014 11:07 pm
by modpopcomedy
Franspeed rhs, DSE from sip...though bigger carb would be needed...as well as earplugs...lol....or check out nordspeed. I know u said u wanted revs etc....but tbh...the gains from the bg bigbox, in revs power and.......torque. as a bonus........are as good as any expansion....especially as u still use si carb. Scorpion like mallosi as well.
