What's your favourite 210 malossi exhaust
ricalnic
Ok, currently I run a Taffspeed RHS exhaust on my Malossi 210. Running T5 4th, ported cases, cut crank, and high flow std si24 carb. It's a great exhaust and comes on pipe at the higher revs. Better than the Revolver that I had on it before.
I'd like to try something else this year, so what do other Malossi 210 riders use and rate ?
I'm not after a torque tour monster, I want revs, speed, power......more...
What have you got ?
bazman
Holed piston.. :lol:
JL Right Hander :D
LI150
Main scooter: Series 2 LI150
I use a JL right hand.
Have you looked at the bullet pipes I fancy one of these next.
http://www.pipedesign.de/engine/index.php
Norrie Bodge
PM-Evo with similar setup to yours but using a T5 24/24g carb...
Vroooooomm
modpopcomedy
Main scooter: vespa sprint 177 polini rv
Franspeed rhs, DSE from sip...though bigger carb would be needed...as well as earplugs...lol....or check out nordspeed. I know u said u wanted revs etc....but tbh...the gains from the bg bigbox, in revs power and.......torque. as a bonus........are as good as any expansion....especially as u still use si carb. Scorpion like mallosi as well.
