parmakit ....so underated
parmakit kid
Main scooter: vespa px125
everyone talks about quattrini,falc malossi just had mine on a reliable dyno and its making 30.2 hp now id say that's pretty good from a 177cc kit and theres still some left in it to tune according to my dremmel man .. it lifts the front end up at 50mph in 3rd gear...NO s**t..!!!
That sounds lovely. You must be very pleased.
Muttley McLadd wrote:That sounds lovely. You must be very pleased.
Lol
mick1
Main scooter: Li Avanti 225
parmakit kid wrote:everyone talks about quattrini,falc malossi just had mine on a reliable dyno and its making 30.2 hp now id say that's pretty good from a 177cc kit and theres still some left in it to tune according to my dremmel man .. it lifts the front end up at 50mph in 3rd gear...NO s**t..!!!
Would agree with your "dremmel man", 30.2 HP seems a bit conservative for a Parmakit, would be expecting more mid 30's. Maybe a big carb' and an expansion would help.
parmakit kid
im well chuffed with it and the best thing is it rideable and a fantastic kick up the arse if ya want it .... it was making 21lbs per foot torque
Are you going to share the spec?
Guessing it's not bolted on with a 24 mil carb and a SIP road, as that's 16hp.
parmakit kid
Spec is 60 stroke worb5 crank,bgm reed valve with 350lc reeds, right hand jl pipe and 28mil dellorto run through the air box.... Oh and tuned by my mate Darrel Taylor
philhnottm
Main scooter: px (s)
parmakit kid wrote:Spec is 60 stroke worb5 crank,bgm reed valve with 350lc reeds, right hand jl pipe and 28mil dellorto run through the air box.... Oh and tuned by my mate Darrel Taylor
My parmakit with similar set is nearly 20 bhp on the dyno with similar set up. GPS top speed 78mph cruises GPS 67 mph.
Then saw Darrel Taylor which I guess explains the difference !!
GLscoot
Main scooter: Vespa GS150
Is that on LML casings or PX modified casings.
parmakit kid
It's on px cases no welding just ported to match.... It made 19.5 straight out the box on the same set up then my dremel
Man got his hands on it and did his stuff I'm going up to a 34 mil carb on it though and that's it job done oh and a sip curly pipe.... Where do you stop it's endless if ya want it to be
    Users browsing this forum: Ahrefs [Bot] and 1 guest
