wassel 12v on li 6v points stator
Posted: Fri Jan 31, 2014 11:45 pm
can i use a 6v stator with points and fit a wassel unit to supply 12v dc lighting,converting the stator to 12v as back in the seventies?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
To run the wassel 12v system the stator needs modifying (as per 60's conversion) as there won't be enough power. You need to add the main lighting coils from another 6v stator (in parallel) with the originals.scooterslag wrote:So do you have to alter the 6 volt stator? Or can you run the wassel 12 volt system with it as is?
cheers for the info chap, you wouldn't know where I could find some more information about the 60's spec stator modification? cheers Paulfirekdp wrote:To run the wassel 12v system the stator needs modifying (as per 60's conversion) as there won't be enough power. You need to add the main lighting coils from another 6v stator (in parallel) with the originals.scooterslag wrote:So do you have to alter the 6 volt stator? Or can you run the wassel 12 volt system with it as is?
