Trunnions
sydduckett
should you use two discs in the mb ss trunnions? They come with one but sticky recommends two when using this type. Iv also found that they tend to fall to the side of the cable meaning the grub screw is tightening down on the leading edge as opposed to the flat face of the disc.
Any tips?
Ta Sef
wack 63
Main scooter: '71 GP TS1
Stick it to the screw with a dab of grease
sydduckett
wack 63 wrote:Stick it to the screw with a dab of grease
I did think about that but didn't want to use grease if poss. thought about super glueing the disc to the bottom of the trunnion. also with the one disc on top, the cable seems to fray. May just go back to the old brass ones with the one disc.
