VHB 30 settings
Looking for some ball park pointers for a 30mm VHB on an Avanti 225 standard tune JL3/Supertourer. Probably going to run it open mouthed.
Current details are:
Slide - 7454.50
Needle - V3
Main - 122 (I think...not very clear :roll: )
Choke - 70
Pilot - 55
Atomiser - 265N
The needle jet seems to be fixed?
Colin
coaster wrote:Looking for some ball park pointers for a 30mm VHB on an Avanti 225 standard tune JL3/Supertourer. Probably going to run it open mouthed.
Slide - 7454.50
Needle - V3
Choke - 70
Pilot - 55
Atomiser - 265N
As an update, I gave it a good clean a and notice that it is marked a VHB30 AS and has a 14g float, anyone know if this a 2 or 4 stroke version? What are the differences?
Ta
Colin
Colin
VHB whassat? VHS series comes in B, C, H & T. I though Ron originally set up the Avanti with a VHSH 30CS ???
corrado wrote:VHB whassat? VHS series comes in B, C, H & T. I though Ron originally set up the Avanti with a VHSH 30CS ???
VHB = 1970's old school carb of choice, solid mount square slide down draught.
OAP
Hi Colin, it is a 2 stroke.
Slide - 7454.50
Needle - V3
Main - 125
Choke - 70
Pilot - 55
Atomiser - 265N
You need to check that the needle is in good condition & the slide, New V3 needles are rare & make sure they are the right length. the above is a good point to start. If you get stuck you will have to bring it over. That is when it stops raining, so I'll see you in a couple of years time then.
If the carb is in good condition they work well.
Cheers Ron, I'll look forward to bringing it over some time, the needle is visibly worn where it goes through the slide. Just LOVE the induction noise they make with the ram pipe fitted
siobhanellis
Just helped me big time :-)
Those slides are bloody expensive..... if you can find one. The V3 needle is on ebay at the moment.
Siobhan
Siobhan
It's not a bloody vespa!
siobhanellis wrote:Just helped me big time :-)
Siobhan
Oops sorry Siobhan, I forgot about this post or I would have mentioned it on your other thread :oops: I'll have a look at the needles although I haven't done any more with mine just yet.
siobhanellis
Hey, no worries. Parts all ordered and I should be good to go! yay! :-)
This is what it's going on: https://www.facebook.com/photo.php?fbid ... 3edbaf6e3c
Siobhan
siobhanellis wrote:Hey, no worries. Parts all ordered and I should be good to go! yay! :-)
Nice although the embelishers don't do it for me personally, are you going for open mouthed with a hole in the panel?
