Reed petal to housing clearance
Posted: Thu Jan 09, 2014 7:49 pm
by vince
Gents with knowledge ::
I am in process of fitting a reed valve on a non reed engine and because of the reed I am using this involves building the reed housing from scratch.
The question I have what clearance do I have to leave between the reed petals and the housing the reed fits into to give clearance for the petals to open ?
Re: Reed petal to housing clearance
Posted: Thu Jan 09, 2014 9:51 pm
by GLscoot
Are you using a manifold and what type of reeds are you using.
Posted: Thu Jan 09, 2014 11:48 pm
by vince
Building the block as it going straight in and fitting a V force reed assy.
Posted: Fri Jan 10, 2014 12:03 am
by Darrell Taylor
try buying a scrap cylinder for the reed your using (if cylinder reed) and cut the reed box off it then you have an oem design that has the benefit of the manufacturers r+d time which could be up to 10yrs worth in some instances
Posted: Sat Feb 08, 2014 11:06 am
by fastfrog
on my lth reed block I've at least 11 mm from free edge of the petal to inner housing.
