Reed petal to housing clearance
vince
Gents with knowledge ::
I am in process of fitting a reed valve on a non reed engine and because of the reed I am using this involves building the reed housing from scratch.
The question I have what clearance do I have to leave between the reed petals and the housing the reed fits into to give clearance for the petals to open ?
Tuning on the tarmac dyno of life............
GLscoot
Main scooter: Vespa GS150
Are you using a manifold and what type of reeds are you using.
vince
Building the block as it going straight in and fitting a V force reed assy.
Darrell Taylor
Main scooter: LAMBRETTA
try buying a scrap cylinder for the reed your using (if cylinder reed) and cut the reed box off it then you have an oem design that has the benefit of the manufacturers r+d time which could be up to 10yrs worth in some instances
fastfrog
on my lth reed block I've at least 11 mm from free edge of the petal to inner housing.
Size matters!
