Jimmers/taffspeed reed inlet manifold
Posted: Mon May 18, 2009 12:58 am
by ScooterLoopyJohn
Here are two inlet manifolds i machined up for a 205 special, one use's a TS1 reed block the other an RD 350 reed block, will never fit under panels but the nuts on a cutdown or skelly.Carb used 35 TMX (TSI reed ) 28TM (RD 350 reed)
With TS1 reed fitted
With RD 350 reed fitted
Re: Jimmers/taffspeed reed inlet manifold
Posted: Fri May 22, 2009 6:53 am
by jimmers
good work john as usual :)
Posted: Mon May 25, 2009 1:44 pm
by fishi
hi mate,
you will use the manifold without putting some boostports into the bore ????
:shock:
Tell us some more details, please !
fishi
