Jimmers/taffspeed reed inlet manifold
ScooterLoopyJohn
Main scooter: 1970 GP 195cc A/F s'type
Here are two inlet manifolds i machined up for a 205 special, one use's a TS1 reed block the other an RD 350 reed block, will never fit under panels but the nuts on a cutdown or skelly.Carb used 35 TMX (TSI reed ) 28TM (RD 350 reed)
With TS1 reed fitted
With RD 350 reed fitted
jimmers
good work john as usual :)
fishi
hi mate,
you will use the manifold without putting some boostports into the bore ????
:shock:
Tell us some more details, please !
fishi
