spit back with mb reed valve
tavspeed
hi chaps,got the new engine fired up today.race rapido 230,been tuned by jb,60mm crank,mb reed valve,pwk 30mm carb,pm25 exhaust.apparently carb was set up for a ts1,and sounds very rich on 0 to 1/4 throttle.
getting quite a bit of spit back through the carb,is this normal with a reed valve with too rich a pilot jet,think it is a 38,needle circlip in the middle,havent tried it on the road yet as a few jobs to do yet,cheers all.
nelson pk
If your jetting is very rich it will still spit back even with a reed valve.
^ agreed ^
Rich at 1/4 throttle might not be a bad thing on a new motor, last thing you want is lean there.
Sent from my GT-I9300 using Tapatalk
best to get it set up on a dyno :)
