Vespa Artago lock
I got given one of these for the pig. It has a bit goes under the seat, easy enough, and a bit that goes into the bar end.
I've fitted the thing into the bar and turned it but it never seems to get properly tight. I think that a right good pull could get it out. Am I missing something?
The instructions aren't brilliant and in Spanish.
Anyone fitted one and got it to work?
Train Driver
I have one fitted to my ex spanish postal, I had Al diablo fit it.
Cheers, maybe Al will enlighten us ;-)
markauk
I've had them fitted on a few scoots, some of the handlebar bolts fit better than others, on the ones that wouldn't tighten up easily I packed them with plumbers putty, the stuff that hardens brick hard
it may be worth a trip to B&Q to see if they have an expanding bolt that is a better size
Cheers, I'd emailed Artago as well, and just had a response from them this morning with decent English instructions and a suggestion that if it still doesn't tighten properly to try fitting a washer.
I'd also wondered if some sort of adhesive might be necessary.
