Rally
cgt75b
Main scooter: lambretta
Another question
Managed to get the flap off the steering lock today. The problem is can't make out the number, think the lock is going to have to come out how do I do this ?
Appreciate any help :D
ArmandTanzarian
Drill out the rivet. Remove the flap and it just pulls out. (At least mine did this afternoon.)
cgt75b
I have the rivet and the flap off ! The lock ain't budging though :roll:
Thanks all the same :D
lambro
You need the key in to be able to pull the lock.
You will have to drill it out, doesn't take long.
cgt75b
I have a key but it isn't the right one, do you reckon that would do with a load of WD40 ? It's seems pretty solid to be honest.
lambro
The key needs to turn to extract the lock.
cgt75b
Ah I see Lambro cheers. You know the lock code is it four numbers ? I don't really want to drill it out :!:
lockman69
Once you have removed the cap Use a drift that fits over the lock (outer ring housing not the inner lock plug)..give it a good belt or two with a hammer, this should break or bend the retaining pin on the back of the lock and it should just pop out...Replace lock or have keys made to your original lock (damaged pin can be replaced) ;)
Drilling the lock out could get messy
Good luck
cgt75b
Ok fella's thanks for the tips I see what I can do !
storkfoot
My rally steering lock code was 6 digits starting with a 5. Hope that helps.
    Users browsing this forum: Baidu [Spider] and 3 guests
