revs breakdown
lammy 225
put rb 250 on dyno today and when u get to 8 thou the spark ,electrics seem to breakdown
had vespa lightened flywheel on standared stator,so off it came for standard sill
flywheel,stator fully advanced now with augusto box on
runs much better but still goes bit haywire flat out like its bouncing everwhere so any suggestions
ie change pick up box,coil blue 1 some 1 said the black are better
ht lead god the list is endless any ideas please
soullad
The Ducati CDI boxes are the best to fit.........just check, it should say so on the unit. If you haven't got one fitted I'd try this first.
Also bypass the Augusto just to check that this isn't causing the issue.
lammy 225
right soullad,will i need to set timing or do i leave it fully advanced if i diss the augusto
my cdi is just standard indian 1 so will change that this week and try again
think its worth persevering as put best in engine then put it in my crappy frame lol
