scootrs disc brake
maskie66
please please does anyone have any detailed pics of how to fit the scootrs anti dive disc with the weld on bracket!! someone must have used the weld on bracket instead of the bolt on bracket!!!! not having much luck with info/ pics
cheers
will
ArmandTanzarian
I think there's a whole thread about positioning the bracket on here somewhere. It's all about getting the parallelogram the right shape (apparently).
I think the idea is to use the clamp on bracket to determine the ideal feel for you, and once you found this you then remove the clamp and weld the bracket in that position.
Craig H
maskie66
craig h you got any pics of bracket welded to fork leg please mate..
will
maskie66
cheers for replys guys
