trailer advise for a vespa
newmanlammy
Been asked to make a trailer hitch for a home brewed pav style trailer to fit on a P range after xmas, anyone done this and can share a few pics with me. just to complicate the issue the scoots got a back rack fitted as well to get in the way.
gaz_powell
squire did a trailer for a px years ago that worked on a standard trailer ball/coupling type fitting - the ball part bolted inside the frame behind the number plate
what about this ?
http://www.singlewheel.com/Scoots/PAV/K ... s/ker5.jpg
http://www.singlewheel.com/Scoots/PAV/P ... -6_B_L.jpg
goldeneye
it also had an extra leg off the frame that went up the lefthand side of the frame of the vespa, and attatched with 2 longer bolts through the voltage regulator holes, to spread the load a bit more. i had one knocking about the workshop for years, probly got binned .
