Yam 125 4t gushing oil through air box!
JoeP
Main scooter: Peugeot S57c 1958
Hello all, recently picked up a cheap '92 Yamaha Beluga xc125 four stroke under the impression the only problem was a lack of spark. Playing with it this evening realised there was petrol/oil leaking everywhere and tracked it down to the back of the carb! There's compression and the bottom end is getting pressurized. I'm going to get the head off to check valves, piston, rings etc but any other ideas about what might be the problem?
Cheers,
Joe
Enough of this modern italian crap ;-)
ForemanBob
Main scooter: GP RT230
Might be a breather tube running from the crank case into the air-box... check it's not blocked?
    Users browsing this forum: No registered users and 70 guests
