kickstart
Posted: Sun Dec 08, 2013 9:22 pm
ive just rebuilt engine on my px 125 with malossi kit, changed cruciform,selector rod , 1st and 2nd gears as they were battered also replaced clutch plates.
puit engine back in and every thing seemed fine, but ive noticed that the kickstart seems to stick/lock.
took flywheel side casing off to see if id not located kstart spring properly, looked to see if id put piston in wrong way up and checked rings , checked to see if exhaust was carboned up but all seems ok......... put electric start flywheel back on to see if this worked and again it seems to turn over one minute and not the next.
any advice welcome.
any advice welcome.
