The Super Monza exposed.
tony
Main scooter: 90ss
psychedelicropcircle
Never seen the windows in the piston sit so high up the piston directly above the gudgeon pin area.
No squish band?
Looking at it I'd guess the head is recessed into the barrel.
^^... it does have a squish band, a centre squish. Yep, it does look narrow, however, the total area probably isn't much less than the area of a side squish but it looks much less as it isn't all on one side. Just about every kit in recent years has had a similar arrangement.
These tuning styles seem to come into fashion, then go out of fashion again, with both being promoted for their respective good points (MSV, central thrust, better cooling, burn speeds, blah, blah, blah...), with both sides saying that they are right.
Adam
Looks a cracking piece of kit, i hear their bloody quick as well.
nellyboyo
I just like the contrasting blue and yellow.....mmmmmmm :D
Spanish Fly
Main scooter: P200e
Why doesn't the charge from each of the main transfer ports p*ss straight out it neighbouring exhaust sub port? :?:
SF
Muppet
i guess port angles an pressure diferences; sum charge mite short circuit at sum rpm; im likin briged ports an wide piston cutaways ova the transfers; makin the skirt narrow inlet side with briges keepin it stable,
muppet,
C’est la vie
steve chapman
hi Tony is it one of the ultimate works kits , if so what number is it and is it yours
thanks Steve
    Users browsing this forum: No registered users and 66 guests
