Px Disc E Start Model Question
philhnottm
Main scooter: px (s)
Apart from the electric start does the battery do any thing other than make the electric start work??
My battery after charge is fine but is not holding charge hence over night no E start
Have to revert to kick start then e start will work for rest of Journey .
So do I need the battery??
Thanks
phil
shamrockexpress
maybe for the horn which you could always convert to an AC horn.
H,POOL GADGE
Main scooter: vespa polini220/gts 300
gadge you need battery for - for electric start - brighter head light - and horn thats all....as what a lot of the lads do is fling the battery plus electric start, have slightly dimmer head light change horn to an AC horn and take starter ring of flywheel....there not worth the hassle batteries n e/starts
philhnottm
Thanks Chaps
Flung the starter, lightened the flywheel, kept the battery for the toys...
Svint1
Have you checked the battery?
It doesn't last for ever, so might try to replace it?
Easier than rebuilding the electrics on the scoot...
President of Roughnecks Scooterclub
http://www.Roughnecks.no
1965 Vespa SS180 (218)
1971 Vespa 90 Racer
1986 Vespa PX250 (250 Rotax on CNC casings)
1987 Vespa PX210 with Cozy Sidecar
    Users browsing this forum: Amazon [Bot] and 2 guests
