ts1 225- whats the best gearing set up?
db67
hi just about run in my ts1 225,i am currently running this engine with a 30mm phbh dellorto with remote filter & jl 3 exhaust,gearing at the moment is li 150 series 3 with 17x48 sprockets giving me a 4th gear ratio of 4:80,is this about right ? or am i way off the mark ! ? thanks for any info. db :)
noggin1969
ts1 225, mikuni 35 & jl 3 exhaust , gearing is li 150 series 3 with 17x46 sprockets works for me giving me 4.7 i think
Has a mind full of useless s**t and isn't afraid to use it !
Bufficus
db67 wrote:hi just about run in my ts1 225,i am currently running this engine with a 30mm phbh dellorto with remote filter & jl 3 exhaust,gearing at the moment is li 150 series 3 with 17x48 sprockets giving me a 4th gear ratio of 4:80,is this about right ? or am i way off the mark ! ? thanks for any info. db :)
4.8 should be fine with a JL3
