Avanti 60mm crank
mick1
Main scooter: Li Avanti 225
If a 60mm crank was fitted to an Avanti with a 1.5mm base packer would any alternations be needed to the barrel (raising/lowering of ports, etc).
What would be the likely benefits or changes in performance ?
Thanks for replies
faf
Main scooter: GP 230 Mugello
I didn't need a packer on mine as the squish was spot on without one,had to take 3mm off the piston skirt though as it was hitting the crankcase mouth at BDC!
