The next step up
Richjak
I am presently running the folloing set up in my bitza cutdown
late type 150 PX engine, polini 177 kit, 24mm (standard PX 200) carb standard PX 150 cut crank Polini exhaust pipe.
The engine casings have been matched to the barrel in the inlet ort has been opened up about 2mm.
Apart from the above everything else is pretty much standard except for uprated bearings and jets.
I am pretty happy with the performance so far, it wont break any speed records but its certainly respectable.
I want to take the next step up and wonder what should come next for a bit of cheap additional power.Crank or carb ??
If its carb it wil be a 28mm PWK item from Scoot RS or a Spaco 26mm standard type carb.
If its a racing crank from SIP, not really sure what the best one would be.
Would welcome any pointers and advice, the engine feels like there is more power on offer, what would be the best buy to do so.
BOTAK ITU INDAH.
Richjak
Wow what an under whelming response 3 weeks and not a single bit of advice, was it worth even posting ?? obviously not.
BOTAK ITU INDAH.
tea5ive
Main scooter: cometa 140
What about an ignition timing gizmo and a run on a rolling road ?.
Svint1
Proper pipe along with the 28 carb.
President of Roughnecks Scooterclub
http://www.Roughnecks.no
1965 Vespa SS180 (218)
1971 Vespa 90 Racer
1986 Vespa PX250 (250 Rotax on CNC casings)
1987 Vespa PX210 with Cozy Sidecar
H,POOL GADGE
Reed valve and a 28mm carb!
santacama
What is the rotary valve timing?
deffo swap the pipe first for a better one ,but retain the std 24mm carb ..but how your crank was cut and how the inlet was modified in conjunction will really affect its power delivery
also did you alter the gearing to take advantage of your kit ?
Richjak wrote:Wow what an under whelming response 3 weeks and not a single bit of advice, was it worth even posting ?? obviously not.
You could check your PMs now and then..
Richjak
Muttley - thanks mate just checked them your a star, sorry for the delay i have been travelling.
Quick update, i have picked up a cheap 28mm Dellorto carb so had some spare dosh for the 57mm flowed race crank.
Whilst i was on the SIP i have also ordered the polini upgear kit 23/64, but as per SIP advise i will run this as a 22/64.
When i get the chance i will fit all the above and see how we go.
Next i will be asking about jetting (have ordered a jetting kit as well)
Thanks for all the advice.
Rich
BOTAK ITU INDAH.
