Reed block
sydduckett
what are the choices reed lock wise for an RB20? building another engine for my rat and I'm a block and carb shy.
Ta
Sef
I'm only aware of the V Force ones apart from the std ones.
Jimmers does an LTH type which allows the Carb to sit back from the panel
That's just the manifold, I thought Sef meant actual reed blocks.
corrado wrote:I'm only aware of the V Force ones apart from the std ones.
You got a link to the RB specific ones?
corrado wrote:That's just the manifold, I thought Sef meant actual reed blocks.
Apologies Martin :(
sydduckett
yeah only after the block, got the standard rb manifold already from when i swapped it for the jimmers one on my series 3. I dont want to spend to much so a standard ones probably the way to go, im supposing the Vforce would be more exspensive?
I could of course get the Vforce and put that in the series 3 then use the standard in the rat.... :D Are there any benefits to the Vforce or over the standard reed block?
Ta
Sef
