Fitting legshield mirror
vRSG60
Any tips on positioning a Stadium rectangular legshield mirror. There doesn't seem to be much mirror adjustment once it's bolted onto the legshield. I can see my exhaust can but I'm not sure I'll be able to see much else. Dark now so I can't give it a proper look.
Timbo
Move it up a bit... :)
vRSG60
Tried that, the further up it goes the more vertical the legshield and thus the worse the view becomes.
Move it down?
vRSG60
soulsurfer wrote:Move it down?
Tried that too :D
Here's where I've settled on positioning it.
bigmuff
Main scooter: matt black indian gp
Turn the mirror head 90 degrees outwards.
^ Agreed, plus if you loosen the nut on the back slightly, the mirror head with move around on a pivot, once set you can tighten the nut up again to fix it in place.
Timbo
And move it down a bit..
vRSG60
Thanks all, I'll give it another go next time I'm at home. I have released the screw on the back of the mirror but find that the adjustment is minimal.
