Page 1 of 3
Badge adhesive
Posted: Sat Oct 12, 2013 10:27 pm
by sydduckett
Have a new lambretta badge for my legshields but the tines are quite short and with the amount of filler in them I'm unlikely to be able to preen them back. Anyone know where you can get ones with longer tines or recommend an adhesive/glue that will work and won't fall off or melt the paint.
Thanks
Sef
Re: Badge adhesive
Posted: Sun Oct 13, 2013 7:09 am
by jazzyb
I use epoxy resin the sort u mix also ad a drop of paint the same colour as panels so it doesn't show 8-)
Re: Badge adhesive
Posted: Sun Oct 13, 2013 1:53 pm
by GLscoot
i use clear gasket paste as it does not damage the paint work.
Re: Badge adhesive
Posted: Sun Oct 13, 2013 3:41 pm
by sydduckett
GLscoot wrote:i use clear gasket paste as it does not damage the paint work.
Is that adhesive enough, what one do you use?
Ta
Re: Badge adhesive
Posted: Sun Oct 13, 2013 4:24 pm
by GP Kevo
If you peen the pegs slightly you can then use the adhesive to "fill in" the rest of the mounting hole around each peg. Then the adhesive will hold the metal of the legshield to the peg, instead of the back of the badge to the paint.
Re: Badge adhesive
Posted: Sun Oct 13, 2013 5:43 pm
by GLscoot
Yes the gasket paste is strong enough to hold the badge in place, all me legshield badges have been stuck on with the gasket, not sure of the manufacturer. I think I bought it from Beedspeed. I also use it on floor runners a long with M4 bolts and nuts, It stops the grit getting underneath the runners and scratching the paint.
Re: Badge adhesive
Posted: Tue Oct 29, 2013 7:45 am
by Lambrettatastic
I've always used super glue gel.
Re: Badge adhesive
Posted: Tue Oct 29, 2013 7:57 am
by soulsurfer
Lambrettatastic wrote:I've always used super glue gel.
+1 It works perfect and it's controllable ;)
Re: Badge adhesive
Posted: Tue Oct 29, 2013 8:42 am
by ducksta
i use black double glasing tape cut it roll into little balls then press and you can get it off at a later date
Re: Badge adhesive
Posted: Tue Oct 29, 2013 10:22 am
by Herman
I once used normal super glue which then ran down three or four inches down the the front of the leg shields. I then tried to wipe off before it dried. It left a white-ish mark the size of a saucer that I never managed to get rid of. I wouldn't do that again.
